hi peeps just wondering if i should gap my new sparks to 0.8 or 0.65 im runnin 12psi on my stock turbo wid turb bak exhaust intercooler should be comin in the next 2 weeks (hopefully depending on cash), ive heard that if i gap them at 0.65 i might missfire more coz of gap being too small thus not sparking unless im runnin high boost(eg 18psi)??? is this true and what gap size would you's recomend???
https://www.sau.com.au/forums/topic/135316-sparks/
0.65 is a really small gap. the smaller your gap becomes the easier it is for your ignition system to cope with higher cylinder pressures (more boost), but the smaller the gap the less evenly it ignites the mixture.
Personally I wouldn't run less than 0.8 - if i need to gap my plugs further than that it's clear i should be upgrading my ignition system instead.
https://www.sau.com.au/forums/topic/135316-sparks/#findComment-2517033
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
