Hi Adam, think I found out what the AC/WG switch is - it appears to relate to choosing either internal actuator or external wastegate.
You running an integrated wastegate arent you, so I guess you would use the AC setting - I can only assume it changes the way the gain affects the solenoid output (difference in sensitivity of a external wastegate vs a integrated solenoid).
copied from a subaru sales website:
The Street Spec Boost Controler or SSBC is an entry level, cost effective boost controller that is very user friendly. There are two available boost settings for high and low boost. This boost controller uses as single solenoid and is capable of handling up to 18psi (1.2bar). The SSBC is 1/4 din size and is compatible with internal actuators and external wastegates.
Call blitz in NSW, they are pretty helpful and may have a PDF of the manual in english (they sent a mate one for his SB-ID)
Ta
Conrad
Hi Adam, I think in the case of units like the HKS EVC its a fuzzy logic unit so yeah it learns your boost characteristics with the end goal of reducing spikes, the SSBC isnt a fuzzy logic one.
The gain adjustment is your main way of setting it up to assure its stable - set the gain too high and it will overshoot, too low and it will never make the boost target in the time you want. I guess its just a matter of striking the balance, and doing some test driving with your boost gauge to get it set up right.
On my previous car, the unichip boost controller was very similiar (no fuzzy logic, just wastegate actuation control in relation to MAP) and it was rock solid and got on boost quick and didnt spike, its just a matter of getting the gain level right I think.
Slayer: I have a Unichip boost module on my car. I ditched it. The Unichip couldn't even hold boost up top. It would drop down and the tuners excuse was it was for 'safety'.
I had it retuned at a later date (different tuner) and this time to get around the 'safety' feature I had a cheap bleed valve setup and it held 1.4bar all the way thru.
Now I've ditched the bleed valve and I'm using the Blitz DSBC. Yet to tune it again so I'm running a measly 1 bar (most of the time)
the DSBC doesnt use the same solenoid though, which is the major part im stuck on...
any ideas? its got 2 hoses coming into the solenoid, and 1 coming out the other side
so you dont have to teach it your boost curve, and the boost levels on HI and LO are preset. so once plugged in theres nothing to configure apart from GAIN. correct?
Adam: The DSBC has two places to put the hoses into it. One to the wastegate (internal/external, doesn't matter, as long as it goes to the wastegate) and one to the map/plenum (boost readout if you will). Labelled out and in respectively.
From above it seems like you're saying there are 3 in the SSBC?
The unit to control boost is similar in both the DSBC and SSBC. Which part do you need help with?
the solenoid itself has 3 plugs
im guessing one is the wastegate, one to the plenum, and one to the inlet pipe
seeing as i dont have a hole in the inlet pipe anymore... ill run 2 hoses to the plenum and 1 to the wastegate
however my wastegate looks like this... it has 2 outlets
The solenoid has 3 plugs. I can't help you there. Are there any markings such as in and out to give you a clue? The DSBC only has two. See http://www.mkiv.com/techarticles/blitz_dsbc/ (figure 7)
But your guessing in running 2 hoses to the plenum and 1 to the wastegate makes sense. In the meanwhile I'll ask around, it sounds similar to the AVC-R soleniod (ie 3 pipes).
What kinda wastegate is it? I've always thought you only needed one pressure line to the WG. I'm down on external wastegate experience, perhaps someone can help Adam here.
No labelling on the unit what so ever?
I really can't help and I'd rather not make any educated guesses. Dumb thing to say, but I take it the instructions are useless. I bought my DSBC second hand, lucky for me they have instructions via a Goggle search.
I'm sure someone here has installed a unit like this.
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
