I was driving alone today my suddenly theres no pressure in my clutch pedal and soon after that i could not engage into gears, any know know what the problem could be ???
hopefully i dont need a new clutch fingers crossed !!
Thanks
Check your slave cylinder on your gear box man :happy: Or your clutch master cylinder on your fire wall.Had my slave cylinder totally blow the seal on me one day... And the pedal went to the floor... :ermm:
Check your slave cylinder on your gear box man :nuke: Or your clutch master cylinder on your fire wall.Had my slave cylinder totally blow the seal on me one day... And the pedal went to the floor... :D
Yeh my dosent go to the floor it bounces back up just not pressure really light and can not change gears !
haha this what happened to me lastnite ....just rang nissan ...total of 25 bucks for the seals...the slave cylinder for the clutch folk was mine...fluid pissed out everywhere. To get it going you have to put into gear first then start car up n make sure nothing infront of u or ull go right up their arse!. was a shit coming to a stop tho!
whats the best clutch fluid to use? nissan one?
was only 17 dollars for the slave cylinder seal kit.....was easy job to do. just have to adjust my clutch engagement now..feels as tho the clutch has to b pressed further down before it bites...strange tho used to get crunch when i go into 4th gear real fast..now it doesnt do it??? any suggestions?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
