post-29722-1159772822.jpgpost-29722-1159772878.jpgpost-29722-1159772957.jpgpost-29722-1159767077.jpgpost-29722-1159595909.jpg
FOR SALE IS A TRUST INTERCOOLER WHICH HAS COME OFF A GTR.
INLET AND OUTLET PIPES BOTH MEASURE 75MM
THICKNESS IS 75 MM
HEIGHT IS 300MM
LENGTH 600MM
IS A DIRECT REPLACEMENT FOR A GTR ALL BRACKETS ETC ARE DIRECT LINEUP OF FACTORY ONES.
NO NEED TO CHANGE ANY PIPNG WHATSOEVER. JUST PULL OLD ONE OUT AND REPLACE.
'TRUST' LOGO STAMPED INTO TOP AND BOTTOM OF COOLER
PRICE $350ono
ITEM LOCATED IN SYDNEY, PICKUP IS PREFERRED. HOWEVER WILL POST AT BUYERS EXPENSE
https://www.sau.com.au/forums/topic/136776-sold/
Can you take pics of the trust badge?
its not a badge its an embedded logo that sinks into the cooler. its really hard to come out in the photo however i will try my best to get it again :(
https://www.sau.com.au/forums/topic/136776-sold/#findComment-2542474
