Hi everyone!
Can someone please point me in the direction of an extrude honing service in Adelaide?
They are quite elusive, white and yellowpages search didn't come up with the goods.
The only company that I can find on the net is Abrasive Flow Engineering in Sydney.
I hope someone can help.
:D
https://www.sau.com.au/forums/topic/137096-extrude-honing-in-sa/
In case anyone is interested, I was just quoted $650 from Abrasive Flow Engineering to extrude hone my standard RB25 exhaust manifold.
They told me they have done them before, and have increased their flow capability from ~130cfm to ~170cfm.
Not a cheap exercise! Nuts :no:
In regards to my setup, since it is the only part of the exhaust tract that has not been modified (ie. enlarged), I'd expect some power gains, how much remains to be seen.
Say you have a setup with a standard exhaust manifold that is pushing the turbo to its limit at the top end, with boost falling off near redline, would this mean that most of the gains from extrude honing be made in the midrange?
What do you guys think?
Cubes, like anything, they are good up to a point. They are certianly good for response. Either way by getting an aftermarket one you are only gaining say, 5% power at the very best so value for money aint there and you have to deal with the tradeoffs (heat/not stock looking/worse response for equal lengths etc).
Turbo Tits, if boost is falling away its more likely the compressor is running out of puff. The manifolds increase the engine's volumetric efficiency, rather than the turbo's capabilities. There might be some gains to be had on the midrange but who knows... Remember you can have the primaries as large as you like but the exhaust pulse still has to squeze thru the relatively squashed turbine housing. Sorta like a storm drain with a garden spray jet on the end.
Just a quick update.
I got in touch with Andrew from Specialised Power Porting in Victoria. He's asking $550 for his extrude honing service. Sounds like a great guy, really helpful and willing to chat.
General turnaround time is 2 weeks. But he said if you call a few days in advance and let him know when the manifold will arrive, he can pencil in into his workload and can have it done in a few days.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
