900W MAX Power
250 watts RMS x 1 at 4 ohms
500 watts RMS x 1 at 2 ohms
V12 AccuClass-D Design
8.5 Volt Input Capability
Alpine V12 PWM Power Supply
Bass Engine® features:
low-pass digital crossover, 30-200 Hz, 24 dB/octave
variable subsonic filter (15-50 Hz in 5 Hz steps)
parametric EQ variable from 30-160 Hz
Bass Compensator enhances low-end definition
Blue Power Indicator
Control Pannel Cover
Digital Control Center with LCD Display (Voltage, Current, and Temp Indicator)
Integrated Wire and Mounting Screw Covers
Remote Bass Knob or Remote Amplifier Control Center (RACC) Ready
condition - used, still got everything that came with the box
selling price $300 with postage
Edited by rootmasta
https://www.sau.com.au/forums/topic/137283-sold/
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
