Morning Gents,
I've got two different idle issues but only one occurs at any given time.
1st: A very small hunt, like 50rpm hunt, it just bounces back and forth a little, only just registers on the tacho but you can hear it in the exhaust.
2nd: If it's not doing that at idle then when gearing down to a complete stop when I put the clutch in and engage first the idle will jump to say 1100rpm then after maybe 1-2 seconds, return to normal. It will do this any time I am coming to a stop and it happens when I engage the clutch.
Background, I've searched about these issues and have removed and cleaned the AAC and AFM. The AAC did have a fair bit of build-up on it and I did my best to clean it, it was literally swimming in carby cleaner :happy: For a period the idle hunt (which at the time was a bigger hunt) went away. The idle increase on clutching has not gone away. The AFM was cleaned with Electrical contact cleaner and the mesh was wiped over carefully, no change.
For reference, car only has a POD with a mr_crust airbox, cat back, low boost bypass on the solenoid and a boost guage as far as mods that could interfer with air flow characteristics, these problems were evident before these mods and have seemingly not been affected by them for the better or worse.
Thoughts? Otherwise I might take the AAC valve off again and totally dismantle it so I can really clean it properly but I'd like to hear other peoples thoughts on the matter.
Cheers
https://www.sau.com.au/forums/topic/137371-idle-issues/
The sensor is no more than 1yr old as I replaced it when I got the car (it was shagged) and my rego is due next week :P The car does smell a bit rich on start and despite checking the seals I still see fuel vapour from the filler cap so I assume the smell is coming from there. The car returns around 12.5-13L per 100 around town so that's acceptable as I understand it.
https://www.sau.com.au/forums/topic/137371-idle-issues/#findComment-2556551
It's been intermittent since I've had the car and I've tried the things above that I mentioned and haven't really gotten far besides when I cleaned the AAC valve which seemed to stop the hunt issue. The hunt comes and goes but the idle jump on engaging the clutch and putting it into gear when approaching an interesection is pretty consistent.
https://www.sau.com.au/forums/topic/137371-idle-issues/#findComment-2562905
Only time I have really seen what you describe is when you put an Auto ECU into a manual car.
The Auto ecu looks at the neutral position sensor on the gearbox and goes ok, you just put it in gear, lets idle up for the load the auto puts on the engine when in gear.
But if you have a manual just because you change out of neutral doesn't mean there is any load on the engine because the clutch is still dipped.
The manual ecu doesn't have this extra idle up because it isn't needed.
If the ecu is the correct item for the vehicle then maybe the clutch is not releasing properly and putting slight drag on the engine when the gear is engaged, does the clutch release fully when dipped?
https://www.sau.com.au/forums/topic/137371-idle-issues/#findComment-2562933
I've had the ECU out before and it 'seemed' normal but I couldn't honestly say if it was right or not, the problem is intermittent thoguh so if it was ECU I doubt it would be behaving this way. As for the clutch booster, how di I tell.
https://www.sau.com.au/forums/topic/137371-idle-issues/#findComment-2562940
I had a similar prob with idle being abit wierd and getting stuck and going up to 1,100rpm by itself. Ended up being TPS cleaned the contacts and all good :D Not to sure if it would help but atleast its something else to look into.Another person I know had a pod filter changed it back to stock ecu reset and good. RB25's r mysterious sometimes good luck mate!!!!
https://www.sau.com.au/forums/topic/137371-idle-issues/#findComment-2563255
Did you see these threads from last week.
Slightly different problem to yourself, but you might as well check the air regulator if you are still hunting for the problem.
http://www.skylinesaustralia.com/forums/in...=135917&hl=
http://www.skylinesaustralia.com/forums/in...=136269&hl=
https://www.sau.com.au/forums/topic/137371-idle-issues/#findComment-2563348
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
