got a blitz boost gauge (AC meter series)
retails for around $360
gauge has been in my car 1 month and is in perfect condition.
reason for sale is i have upgraded to an electronic boost controller and it has a built in gauge
price is $180
0438551785
i can get pics of people wanna see
just do a search on blitz AC meter gaugs and thats what they look like
they are EL white background with laser red needle. best looking gauge on the market i think
cheers
Edited by 21AZY
https://www.sau.com.au/forums/topic/138118-sold/
