Engine In, Engine Out... That's What It's All About!
  • Replies 54
Guys that is a monster performance i have to say.
So slide i see you like to work for steaks? You and i are going to have to become friends cause when the GTR comes along i can see some work coming with it.......Mod work of course!
Now now, don't you go using and abusing my slidez0r... i'll f*k you up good and proper if you do :(
Now It just needs the monster turbo to go with it!
After hearing Jarrads car I want external gate lol
*slaps forehead* oh dear :O
what are you talking about its quite as :P
baaaahahah ah ha ha ha
Actually the fuel pump is WAY louder than anything else :):D
Well my engine has gone.. very sad moment actually crashing the car 5 weeks afta it spends 7 months in a shop is a sad moment.. I am suprised we got it done just ask slide normially working at my house takes longer then it should with everything on cars.. Ohh and u owe me a ride now in that 32.. Go the paint job i must have known when i painted it it was going to go in your car good colour match lol..
Enjoy the engine...
I know how crazy is the colour match! It was just meant to be! Thanks for everything mate ;)
Now now, don't you go using and abusing my slidez0r... i'll f*k you up good and proper if you do :)
Me use and abuse???? :D I would never do that to a fellow skyline enthuseist (spelling??)
sorry aaron, but we rnt gay like those southerners :)
Yeah the NSW family is alot stronger and larger then Qld
I will allow you to buy parts from me aswell :)
Enjoy the engine...
Nobody likes fags that ride bikes :)
what are you talking about its quite as :D
Its only loud because the gate opens 5000rpm before it should.
And stop thrashing it when you just turn the car on lol it makes me cringe :O lol
And stop thrashing it when you just turn the car on lol it makes me cringe :dry: lol
I cant thrash it because I can go above 5500 rpm because the coil packs are stuffed
Enjoy the engine...
Ok you can have a ride after it is tuned (Afterall the tuner is just around the corner from your place!) And yes the colour does match rather nicely! Good choice;)
hahaha whats wrong with bikes.. Bikes are wikid esp when u have to drive to a certain slides house all the time and he lives in tweed so i have to deal with all the traffic bikes are better straight up the outside YES no traffic.. So move closer and i prob sell my bike hahaha.. Ohh i got my new go kart today i will drive that to your house instead then jsut go under cars instead of around...
stop typing like your on a mobile noob and stop bitching :mad:
you love me :mellow:
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
