hey guys im selling an r32 GTR VSPEC that i have recently imported for myself and wanted to use it for track, but unfortually for my to put it on the track and have it all decent and shmik will cost me a fair bit which right now i dont have funds for..
its a 93 GTR Vspec
Slottered Rotors
71,000 on the clock
AFTERMARKET CoiloverS
Vspec DIFF
Twin Air Filter
Greaddy Turbo Timer
HKS IC PIPPING
TRUST INTERCOOLER
6 months rego left
FATT Aftermarket wheels
MANY MANY EXTRA'S
$20,000k FIRM
this will be one of the most cheapest R32 GTR VSPEC that is going around. i know im going crazy and i know but i want to SELL ASAP
i have 2 cars at the moment so this baby is just sitting there wasting Rago...
i dont have updated pics..
but will post some on monday..... My LOSS IS THE BUYERS GAIN!!!!! FARK!!! IT HURTS!!!!
Edited by ZERO
https://www.sau.com.au/forums/topic/139197-sold/
  • 1 month later...
checked the car is not a v-spec checked the numbers standard brakes air con. stereo etc other than that pretty neat think has had a fair bit of boost through it plenum paint really flaked off!!!
thanks for the infor Jeff...
deposit has been taken but car is not gone yet...
anymore interests?
I think you meant "thanks for the infor Chris" not Jeff...
if its still around next week, then I will tee up a time for inspection and a price to suit.
cheers
Jeff
https://www.sau.com.au/forums/topic/139197-sold/#findComment-2757131
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
