  • Replies 78
Actually they stopped allowing runs at 11:15pm because well... they felt like it. So 2 of 2 nites that the weather was fine they ended the night early because well... they felt like it. The other nite it was rained out 1hr 20 after the nite started so of 15hrs racing we've seen 7hrs.
Edited by benm
https://www.sau.com.au/forums/topic/140333-wsid/page/4/#findComment-2684760
NismoGod you got 13.45 with only full exhaust?? What other mods man??
Thats awesome time for just full exhaust.
I got full exhaust and my best was 14.10 at 100MPH but on street tyres
But my launches were really crap but.. Need more practice!!
https://www.sau.com.au/forums/topic/140333-wsid/page/4/#findComment-2684785
siddr20 yeah i got a 13.426 on semi slicks. 60ft 1.997 and 103.5 mph. i have a full turbo back exhaust. its a split dump pipe with 3" system with a 5" hi flow cat. no other mods except a pod. but i really can only take what the previous owner told me. he imported it april 06 and did nothing with it, so maybe something else has been done, but i doubt it cause the power isnt too huge. i did a 13.700 on my 19" which has a 60ft 2.018 at 102.5 mph. there is still some time with the current setup will the slicks, hope to drop another .1-.2 off the time. the more time i go to the drag the quicker im getting so time will tell.
https://www.sau.com.au/forums/topic/140333-wsid/page/4/#findComment-2685345
heheh man i was hoping to get into the 13s to be honest..
I knew i could do it!! i was so close!!
Just wish my launches were better!!
Its all about the launches to be honest.. Only mods i got is ful exhaust (spilt dump also) and pod..
I only had 7 runs, so maybe next time i can get into the 13s..
very impressive with your times btw!!
and yes im jealous!! :D
https://www.sau.com.au/forums/topic/140333-wsid/page/4/#findComment-2691760
Nothing special their tonight except a Cobra, everything else was either a regular or just a VX Commodore bashing in the 13's.
I got to the drags at about 6:45pm and it was 36c, 20mins later it was 23c and so windy I thought the big undercover area at the top was going to lift out of the concrete and blow away.. how crazy is that.
Edited by benm
https://www.sau.com.au/forums/topic/140333-wsid/page/4/#findComment-2695584
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
