Buying R34
Originally posted by nismoR34
I am guessing he scammed a higher rating when he 1st took out insurance [like me :D] Or he was listed on his parents insurance during L's...maybe...
This is normal. I bludged 60% ncb off my olds as well but of course, phuqqed it up the wall with my colourful driving record.
T.
https://www.sau.com.au/forums/topic/14059-buying-r34/page/2/#findComment-299468
Kenshin,
>how much the rego? cuz thats the only cost we gotta pay if we >buy from dealer and i know nothin abt it, since this is my first >time buyin a car =( very sad case i know
The dealers usually give you 3 month registration. You do however have to pay stamp duty of 3% of the TOTAL Value of the car to the rta because it is a used car and trading hands. Ie if you buy privately its the same thing hence ppl on the sheet they bought it for $X thousands less to save on this cost.
https://www.sau.com.au/forums/topic/14059-buying-r34/page/2/#findComment-321407
Guest kenshin
what rate will u give regarding to the crime, chances and damages on r34 by some ppl out there
say the rating will be 1-5, the higher the rating is the higher chances and times that have already happened.
cuz i heard that mazda rx7 is seriously targeted by some ppl, whether they intend to steal the car or a part of it or damage it on purpose.
https://www.sau.com.au/forums/topic/14059-buying-r34/page/2/#findComment-340800
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
