there are a few variables when testing compression, such as;
closed throttle
open throttle
number of cranks
hot test
cold test
so rather than testing for a number, look for even figures across the board.
eg: 140, 139, 141, 143, 140, 139
The compression on my old R32 GTR was 160psi just about dead on with all cylinders except one at 100psi. To check out a piston with lowish compression pour a few cc's (mls) of oil into the cylinder via a small funnel (you only need a little oil, too much is very very bad and may damage things). Let it sit for a few minutes. If the compression on that cylinder shows marked improvement once re-tested to the order of 25psi or greater you probably have worn rings.
That motor was 250,000kms old or so. And the bang on compression between cylinders is perhaps testimony to the fact that the aussie engines were blueprinted from the factory, unlike the jap domestic ones.
Well my GTR returned 150Psi across all cylinders. 6 months later I spun a big end. To read the bearings and to see the pitting on the cylinder head/pistons I say it had been absolutly hammered and seen lots of big detonation events and I can garuntee that it never rattled(detonated) or was run lean in my hands.
Imports are usually an unknown item.
A good result from a compression or leakdown test will verify the condition of:
-Piston Rings
-Head Gasket
-valve seating
-cracked head
-general condition of bores and pistons
it's a good overall test of motor as you would assume these components are in similar condition to the rest of the engine.
It MAY be able to identify damage to:
-pistons
-bores
-valve springs, guides or lifters - or rocker arms if it's an SR20 (maybe... if they are causing a valve to stay open)
(depending on if this damage is causing a drop in compression)
It will NOT verify the condition of:
-Bearings
-Crank
-Conrods
-Oil & oil pump
-other head problems such as stem seals.
You can have an engine with a spun big end bearing, and it could be using mud instead of oil and it will probably still give you a good compression reading! What i'm saying is it isn't a complete indication of the health of your engine.
A leakdown test can pinpoint the percentage of compression leakage and where it's leaking from, but it tests the same things that the comp test tests.
A good example of a BAD compression test was the one I did on my daily driver before i rebuilt the engine.
Dry: 95psi 95psi 165psi 165psi
Wet: 165psi 165psi 165psi 165psi
A large increase in compression indicates piston ring problems...
Pistons 1 and 2 had cracked ring lands.....
http://i2.photobucket.com/albums/y19/merli...dia/piston2.jpg
^ if you look at the piston in the pic this was the damage....
Edited by MerlinTheHapyPig
Is there any way to test the bearing, rods, crank, oil pump?
The bearings where scoured from detonation.
Pull the oil filter off and open it with a heavy duty can opener and look for copper material and or anything suss. If you find nothing then its still not an indication that the bearing's aren't damaged but it may be a heads up for damage allready done.
how is it possible to kill bearings from detonation?
don't you mean pistons?
bearings usually die from forign particles, lack of oil or just general wear / driving it too hard.
You sometimes get little black oval scours along the verticle parts of the bearings. They also loose their tension and depending upon how big the detonation you may actually crush the bearing.
Remember when detonation occurs the bearings are transferring the force to the crank.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
