Hi all
Seeing as the VIC stagea clan has not had a meet in such a long time I though it would be good to keep up with the other states.
As most of us (Alex :yucky: )should have our stags on the road by the weekend of 18th Nov I thought this would be a good time to meet up and actually have a cruise with maps etc
it would also be good to meet some of the new additions since the last meet.
Firstly we need to confirm a weekend and day that EVERYONE will be able to come as it sux when someone misses out.
Secondly when we have a consensus of who will attend then a central meet point can be arranged.
Previously we have spoken about having a Great Ocean Road drive. Any other ideas would be great. Once we have the interests then a route can be drawn up
Give me your thoughts
Cheers
Ian
MEMBER CONFIRMED SO FAR:
1. AlexCim
2. munchdesign
3. Flysly
4. wagon
5. Tracey (non member)
6. Me
DESTINATION:
1. Dandy Mountains then SAU Show n Shine
DATE:
Sunday 26th Nov
Edited by humble
https://www.sau.com.au/forums/topic/141766-vic-meet-cruise-catch-up/
  • Replies 92
So at this stage the Sunday seems to be the preferred date.
so far options are Great ocean Rd and the Black Spur.
Any other ideas would be good.
If you have contact with other stagea guys that done come here often let them know about the cruise
cheers
Ian
Sounds ok, I will have to check that date.
Do we want to list up the Vic Stagea owners? There are 6 that have replied here so far, I know there are more, lets see what we can do...
VIC [ 17 ] [24.64%]
1. FLYSLY
2. FUZZY
3. AlexCim
4. munchdesign
5. humble
6. wagon
7. MRNISN
8. stasis
9. japshere
10. oxford1327
11. bluesky4me
update:
12. Ian
All I can find, sorry if I missed ya!
Cheers
Luke
Edited by munchdesign
soz guys i might not make it. Im not in the country and i dont know when will i be back as i am enjoying my newly born second son on the 1st. But if i make it before the 18th i will definetely make it.
Correct me if im wrong but Nov 18th is a saturday, if this is the date i am not going to be able to make and if its sunday 19th of nov i wont be able to make it either, but any other sunday would be sweet.
Please make it on a day im free i really wanna meet other Stagea owners and check out there cars!
I have the 19th marked down as a tentative at this point, a Saturday or Sunday is fine with me.
There are a few clashes happening on the 18th so I think that might be too hard for some people (or not possible at all). Should we be looking at another date just to give some options? Is a Sunday possible for everyone as it sounds like FLYSLY (Simon) can't make a Saturday at this stage? Sorry for hijacking Ian, I will let you run this, I'd like to see as many Stagea's there as possible! :)
Cheers
Luke
Oh and congrats Yudy! Enjoy!!!
Nice one Yudi congratulations mate. They are a blessing.
Luke mate no stress. This is a group thing so any suggestions would be great.
It seems that the weekend of the 18th and 19th might be a bit short notice for everyone. What about the weekend after that??
As you said luke it would be awesome to have everyone one come along
how about people post up dates that would suit them best and take it from there.
Gareth get an autograph for me you lucky bugger
cheers
Ian
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
