Hi all
Seeing as the VIC stagea clan has not had a meet in such a long time I though it would be good to keep up with the other states.
As most of us (Alex :yucky: )should have our stags on the road by the weekend of 18th Nov I thought this would be a good time to meet up and actually have a cruise with maps etc
it would also be good to meet some of the new additions since the last meet.
Firstly we need to confirm a weekend and day that EVERYONE will be able to come as it sux when someone misses out.
Secondly when we have a consensus of who will attend then a central meet point can be arranged.
Previously we have spoken about having a Great Ocean Road drive. Any other ideas would be great. Once we have the interests then a route can be drawn up
Give me your thoughts
Cheers
Ian
MEMBER CONFIRMED SO FAR:
1. AlexCim
2. munchdesign
3. Flysly
4. wagon
5. Tracey (non member)
6. Me
DESTINATION:
1. Dandy Mountains then SAU Show n Shine
DATE:
Sunday 26th Nov
Edited by humble
https://www.sau.com.au/forums/topic/141766-vic-meet-cruise-catch-up/
  • Replies 92
So at this stage the Sunday seems to be the preferred date.
so far options are Great ocean Rd and the Black Spur.
Any other ideas would be good.
If you have contact with other stagea guys that done come here often let them know about the cruise
cheers
Ian
Sounds ok, I will have to check that date.
Do we want to list up the Vic Stagea owners? There are 6 that have replied here so far, I know there are more, lets see what we can do...
VIC [ 17 ] [24.64%]
1. FLYSLY
2. FUZZY
3. AlexCim
4. munchdesign
5. humble
6. wagon
7. MRNISN
8. stasis
9. japshere
10. oxford1327
11. bluesky4me
update:
12. Ian
All I can find, sorry if I missed ya!
Cheers
Luke
Edited by munchdesign
soz guys i might not make it. Im not in the country and i dont know when will i be back as i am enjoying my newly born second son on the 1st. But if i make it before the 18th i will definetely make it.
Correct me if im wrong but Nov 18th is a saturday, if this is the date i am not going to be able to make and if its sunday 19th of nov i wont be able to make it either, but any other sunday would be sweet.
Please make it on a day im free i really wanna meet other Stagea owners and check out there cars!
I have the 19th marked down as a tentative at this point, a Saturday or Sunday is fine with me.
There are a few clashes happening on the 18th so I think that might be too hard for some people (or not possible at all). Should we be looking at another date just to give some options? Is a Sunday possible for everyone as it sounds like FLYSLY (Simon) can't make a Saturday at this stage? Sorry for hijacking Ian, I will let you run this, I'd like to see as many Stagea's there as possible! :)
Cheers
Luke
Oh and congrats Yudy! Enjoy!!!
Nice one Yudi congratulations mate. They are a blessing.
Luke mate no stress. This is a group thing so any suggestions would be great.
It seems that the weekend of the 18th and 19th might be a bit short notice for everyone. What about the weekend after that??
As you said luke it would be awesome to have everyone one come along
how about people post up dates that would suit them best and take it from there.
Gareth get an autograph for me you lucky bugger
cheers
Ian
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
