Well, its still stockish hehe! All the mods so far have been performance mods, just boost controller, pod, split dumps and high flow cat. Nothing visually. Im happy on how it looks so far, later down the track ill prolly get lowered, new rims and a spray to silver cause it looks so sexy! :wave:
10k? Dam that is a good price... i payed 16 for mine...
Looks nice, another silver r33, wish i found one hehe!
Yeah its great, runs perfectly no major problems.
Few kinks in the body and the salt from shipping
caused a bit of paint damage :) Otherwise perfect
car =D!
Fixing the little bits of damage and respraying in Dec!
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
