R33 Parts ( Burnie ) Big Price Drops
hey guys, got a bit of stock R33 s1 parts for sale. Mske an offer as it all must go to make room for workshop. don't really want to freight stuff unless buy organises freight, htats why i havn't advertised in the main forsale forum. you can contact me on 0408126063 or just pm me, cheers dave
Front Bar $50 SOLD
Rear Bar$40 SOLD
struts and springs full set $80 SOLD
King springs lows, full set $120 SOLD
front and rear seats $250
2 x parcel shelves $10
full boot interior $70
interior plastic panels excluding door trims. $80
genuine floor mats excluding driverside $15
glovebox and assembly $15
std cat back exhaust $35
s13 cat back exhaust $30
intake plenum with cross over pipe $50
4 stud silvia rims with semi bald tires x 4 $60
Edited by guesty
https://www.sau.com.au/forums/topic/142146-r33-parts-burnie-big-price-drops/
Hay mate, interested in the King springs Low set, and the floor mats, well actually just the driver side, but give us a price. I can arrange freigh to Lton and then i'll pick it up form there.
PM me with some prices, you have in mind and i see what i can do.
So the kings are Lows, not super lows. My car is stock and already have problems getting in and out of the driveway, but want it about 1" lower. So lows are good.
Price is right, but need to see finances, got to also buy EBC.
How much for the floor matts?
yeah, they are just lows, dropped it about 30mm, alot stiffer than standard. i have the back pair of mats, with the drivetrain piece, and the front passenger mat, can't find the drivers side anywere. about $20 for the mats
Dam the matts, it's so dam hard to find a driver side one. I have the other just need a driver side one.
On the springs, sorry mate but it looks like ineed to spend my money on the coils first, their braking down again, allready at .6mm gap. DAM IT.
  • 1 year later...
Front Bar $50
Rear Bar$40
do you have the turbo for sale i need one asap i only live in wynyard in tas and i need a driver side window channel as well so can you please get back to me asap
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
