Hi all
Well tonight my bro was driving and being stupida as we all do, late at night, nice and cold outside, and my car went all the way to 14psi after the FMIC, so propably 16psi on the turbo side.
I have a FMIC and turbo back exhaust, SAFC II tuned and HKS pod, ect ect, stock boost controller, and the boost went up top 14 psi. I am looking at a GIZZMO IBC but this is weird. The highest i ever saw it before was 12psi, but normally lucky to see 10psi.
What the hell is goign on and how do i fix it untill the GIZZMo is in????
And befor i get flamed, it was on a dual higway with just us two and NOOOOOO cars, and it was my brother.
So you're seeing 14 instead of 12psi? Easy answer could simply be that at night you're seeing boost spiking abit higher due to the colder denser air. I see my boost jump up to 9-10psi at night from the 8psi I see during the day on my ProfecB2.
Off topic, I remember you writing a thread about the SAFC. Have you been able to rid the notoriouse R&R using the SAFC?
Well it sure scared the hell out of me. But yeah i am sure it had to do with teh cold night and denser air. Can't wait for an EBC to fix things.
As for the R&R, yess i managed to get rid of most of the issues, we bumped teh fuel pressure up, only 3 psi and then tuned down the SAFC to the point where the R&R disapeared, but the stock computer not taking timming out.
It took some time, and there is still a little flat spot, but not as obvious as it was.
Having done all this i just purchased a mines ECU, so we see how that goes.
perhaps your exhaust is the problem, if it is free flowing enough air will go through the turbo still when the wastegate is open. air goes the easiest way...is that a tiny wastegate hole or the already spinning turbo with nothing behind it?
can someone please lend a knowing ear?
you can't get much more free flowing them mine, 3" dump, no cat, and an oval 3" muffler with 4" tip. it's free alright. LOL
I think it's the stock boost controller not working with so many modifications.
Shut up and grow some balls.
Big deal, my brother was driving wayyy over the limit, not like you haven't done it. So give up. I try not to do it, my brother was driving as it was his first drive ever in my car.
RELAX. it was very late, no cars on the stretch of highway we were on, and even if there was, centre divide so I couldn't hit them anyway. I am getting sick and tired of people thinking that if you speed, you are dead. I have been racing on tracks since I was 13, have had accidents and learned, never do anything stupid on the real roads, and if you look at my driving record, it's %100 clean, and I have been driving for 8 years.
SO lay off grow some balls and stop pretending that you leave in a society where people are perfect, your not and neither is anyone else.
THE END.
So before you call people a moron, GET YOUR FACTS STREIGHT. just cos your the MOD, don't mean stuff to me.
I think it was more they dont want to be seen promoting speeding as this is a public forum. Talking about drifting/speeding/doing burnouts in public areas you will find is a no no on these forums. Would you really want to see a newspaper article laying shit on 'hoons' and a big screenshot of these forums with people bragging about what they have done?
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
