hey guys
i just bought a set of gt2560rs -5 for my gtr
just curious is it as simlply bolt the old turbos off and on with the new ones, do i need to modify anything??
also can someone please list all the gaskets i need??
and one more question my engine istock with no other mods beside, full exhaust and airpods, is alrite to run these turbos at 1 bar??
thx guys Ali
https://www.sau.com.au/forums/topic/144752-gt2560rs-5/
thx for that guys, y do i need to drop the boost?? and also wat do u mean by slot the oil drain bolt?
thx again
Those turbos flow more alot more air at 15psi than stock ones. More air but, only the factory fuel and ignition maps that are suited for the smaller turbos. The factory ecu does run fairly rich usually so you have a little head room for power but, those turbos have a fair whack more power potential than you have margin for error. The main issue may not be right up top either but, rather the peak torque point which on those more efficient turbos will possibly be higher than factory at the same point the factory turbos make peak torque.
Bottom line is you don't want to go guessing that 15psi will be good clean fun. Get the boost right down as low as you can and then throw it on a dyno and see what you can take it to boost wise without getting yourself a Power FC or S-AFC ,at least something. You might be able to run 15psi but, without taking it there under dyno or O2 wideband observation you may find a new bill sitting in your engine bay.
https://www.sau.com.au/forums/topic/144752-gt2560rs-5/#findComment-2704258
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
