Hi all
I have a used 3" Kakimoto R muffler that came off my R34 GTT. It is one piece and includes the muffler and piping up to the axle/diff. All STAINLESS STEEL.
It will fit all R34 GTT coupes. ie. lines up with the stock rubber hangers.
It should also fit R33 GTST's.
It is quiet, has a nice deep tone, and no drone. This is a quality system from Kakimoto.
This is in excellent condition, comes up nice and shiny as you can see.
If you are sick of your cannon, or tired of your loud/cheap exhaust note, this will be a good replacement.
$280
In Sydney. Please PM for further details.
Cheers
https://www.sau.com.au/forums/topic/144796-sold/
  • 1 month later...
Just to clear any sort of confusion, please note I am selling the muffler and some extra piping that extends to the rear diff, not all the way to the cat. Any exhaust shop can easily make the section to the cat pretty cheaply.
This is not a full cat back system. As seen in the Kakimoto website pic in the thread, it is only the muffler with the little extra piping that ends near the rear diff.
Thanks again all
https://www.sau.com.au/forums/topic/144796-sold/#findComment-2787044
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
