Nah mate im up in Townsville North qld
Its coming with a turbo so if i dont use it its no biggy Ill just put turbo on stock manifold
I dont even know what kinda increase there would be if any ,its just ill have it and thought why not
heys I've checked with a certain performance shop mechanics, he said if whatever manifold you getting is good quality, it'll fit exactly...
however chances are your manifold will be made in China, there'll be a bit off missmatch, you just have to bore a wider hole for some........
also as you purchase the manifold you have to make sure 3 things
1- all surfaces are flat, the flange where the manifold connects to the engine block and the connection to the turbo (sit the surface on the ground to check, machine them if they are slightly curved)
2-The manifold lengths have to be relatively simmilar, if you have two longer outer pipes and a much shorter inner pipes it will cause some heating and backpressure problem in the inner manifold
3- where the external wastegate pipe is welded on, make sure the position is where all the 6 pipes joined. Some manifolds have their external wastegate inlet welded onto one pipe only. Not a good idea as the pressure from the remaining 5 manifolds will not be released, causing overboosting problem
and performance wise, it is not recomended to change unless necessary such as changing into top mount turbo
cheers
thanks
yeah I would only put on there for wank factor (ooohhh shiny parts )
but im going stealth with my car so ill stick with stock looking stuff
it keeps the popo from harassing me
and ive only got a target power goal of 240 - 250rwkws so its not going to help me much having it on there
so ill sell it and get my 480cc injectors
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
