there's nothing in the way of it on an RB25DET, so in theory yours should have even less in the way...its right down in there, not exactly easy to get at, and it'll probably be covered in shit....so you'll need to wipe it down to be able to read it
https://www.sau.com.au/forums/topic/145255-engine-number/#findComment-2714564
They probably just farked it up on the RWC anyway...your car has an RB25 in it so I wouldn't be too worried..
When I got my RWC (being the first time it was registered in Aus) the RWC place left off the 'RB' part of the engine number.....I didn't notice. Rocked up to my appointment at vic roads and he sent me on my way, and made me book a new appointment just because of that. Had to get a re-write on my RWC etc
https://www.sau.com.au/forums/topic/145255-engine-number/#findComment-2714775
thing is, this guy wants to buy it and wants to find out about it so i gave him the vin and the engine number that was on the rwc that i got with the car. then he says he called and the engine number doesnt match the vin :P
could be just a typo....? i'll tell the guy to put RB25088570A instead of RB20088570A and see if its right
https://www.sau.com.au/forums/topic/145255-engine-number/#findComment-2714804
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
