Hey guys..Just want to see what everyones opinions are.I have a 240z with a rb25/30 gt35r 1.06 exh,external gate,microtech,greddy plenum,injectors etc etc.Its stock internals but rebuilt with race series bearings,linished rods etc.Its making just a tad over 500rwhp...
The car is about to twist its self in half.That much power is unusable in a rwd not to mention dangerous in a car weighing 1020kg.I could put slicks etc on but i dont really race it its just a cool street car so i dont want to.
I have been trying to sell my 32 gtr for a while now and the market is dead.For the prices ive been offered id rather just keep it and put the 240z gear in it.
Question is,do i put the 30 bottom end in (with the 26 head) and all the other gear (turbo,injectors,microtech etc) OR just freshen up the 26 and put the turbo etc on it.I love the torque of the 30 but i love the revs of the 26.Never driven/been in a 26 with decent size turbo/s etc (mine has n1's and they suck!).
does the 4wd block adapter have any problems?how strong is the 30 block in 4wd form.obviously it will have more stress on it than in 2wd.
Opinions?
https://www.sau.com.au/forums/topic/145550-26-or-30/
Opinions?
Strengthen up the 240Z, they are notoriously flexible. Particularly the C pillars. Put some decent suspension in it and it will be fine. After all its only 100kgs lighter than my R32GTST which has 600+ rwhp.
:( cheers :woot:
https://www.sau.com.au/forums/topic/145550-26-or-30/#findComment-2720731
rb30 blocks have known to break under the stress the front diff acting on it, the 26 block has extra webbing to support the torque of the front diff but then again there are gtrs out there with the rb30 block that go well with around 100hp more at the same boost than the rb26, ur defintely not wrong about loving the way the 26 revs, many people do lol
https://www.sau.com.au/forums/topic/145550-26-or-30/#findComment-2720737
hi, can you please tell me what rb30 blocks you know of that have broken when used in 4 wd?
https://www.sau.com.au/forums/topic/145550-26-or-30/#findComment-2721913
i rekon you should bolt the turbs on. thats what ive done. t04z 1.2 bar on a origonal r32 gtr engine. its putting out 315 awkw.
ive got a fullly built motor ready o drop in but itsnot showing any signs of dying so its just sitting on the stand lol
https://www.sau.com.au/forums/topic/145550-26-or-30/#findComment-2722992
    • I'll give it a go, it cannot hurt Although, every time I go to Bunnings for one thing, I end up with a trolley load of stuff In other stuff news, I can fit 6 x 15kg bags of Gypsum in the boot of the MX5, I could have put a few more in, but I was already pushing my comfort levels buy dropping 90kg into to boot....LOL
    • It seems to happen only when moving not stationary. It happens more frequently when reversing and turning steering wheel to the right. I MAY have found what the sound is and if it’s that I will feel so dumb since it did start happening around when I put 18” wheels. I attached the image of where there’s a scraping line to that plastic liner and the other side does not have that.
    • Is it a noise that if you turn the wheel, and hold it turned to the right, the screech continues? Or does it only occur while you're moving the steering wheel? Does it occur when stationary turning the steering wheel from centre to the right?
    • I want to also note I did lift the tire and checked for any play to see if it was a bad tie rod. It doesn't move at all.
    • Any insight will help find the issue. When I do a sharp turn to the right I hear a screeching sound coming from the front. It only happens turning Right and not Left. Steering fluid seems okay. Not sure what this part is(picture) but one side seemed "wetter" than the other. All bushing from a quick look did not seem damaged. I'll do a better look but wanted to ask here in case it helps me troubleshoot faster.
