need a few parts for a series 2 rb25. some should be the same for all models..
i need:
crank angle sensor with stock disc
air flow meter
oxygen sensor
temperature sensors (screw into the top heater fitting on the inlet runners.. 2 of them)
injector harness
rb25det head oil return tube (the pipe that bolts to the exhaust side of the head near the front)
1 fuel rail mounting spacer (black plastic thick washer that sits under the mount for the fuel rail to the runners with a bolt through it)
1 injector retaining cap screw
oil return fitting:
temp sensor holes:
fuel rail mount spacer:
and where it goes:
cheers guys, Kent
Edited by R31GXE3.0
https://www.sau.com.au/forums/topic/146726-wtb-rb25det-parts/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
