I don't think it's as easy as holding it a 4800, they measure when you back off from that so incase it backfires and getting to that RPM, I have done ir before at work for a blue slip and tafe.
They also test starting your car
Cheers
Josh
faaaarken hell. my exhaust is 102dB WTF???
i held 3500, then held 4800, then back down. the highest reading was 102db.
and to make things worse, we couldnt fit the oval resonator on, coz there's not enough room under there.
that would have only brought it down maybe 3dB anyway. but the only option is to put a hotdog resonator which will only reduce it by maybe 1 or 2 dB.
dangnamit :laugh:
the way he measured it was 45degrees left of the tailpipe, about 1metre away. is it possible he was too close? i might go somewhere else and get a reading.
edit:
before my highflow cat, the exhaust didnt seem this loud. i assume the cat has increased flow dramatically, causing increased volume.
i didnt expect it. is this pretty normal of a highflow cat? it's only an xforce 3 inch cat (replaced a standard compliance cat).
Edited by Munkyb0y
I had my exhaust tested a few years back and I'm sure things haven't changed much.
The process back then was:
Place the microphone at 45deg and 0.5m from the end of tailpipe.
Increase revs gradually to 75% of max hp of engine (this turned out to be 4200rpm for a skyline (any model skyline??) as indicated in the EPA manual, I didn't argue for a more accurate figure because more revs = more noise). Increase in revs has to be gradual so the reading does not spike, otherwise they have to start again. Same goes for backing off. They are not measuring dB under acceleration, they are measuring a simulated drive by situation at constant engine revs.
This process was repeated exactly when I fixed the exhaust and was retested.
I'm running a 3" front pipe off the standard dump, 3" high flow CAT, into 3" pipe with a hotdog inline with a small box resonator, and a 6" barrell muffler with a 4" tip. Tested at 89dB.
Without the box resonator I was tested (and fined) at 92dB. A hotdog will only knock off 1-2 dB. NSW EPA regulation is a maximum reading of 90dB.
Z.
Z.
i'm running the exact same setup as you, minus the box resonator and hotdog. where the hell did u get the box to fit? if i put it on, it would be hanging way too low, or touching the tailshaft. mine is all mandrel bend, so it kinda takes up alot of room with no harsh bends.
i reckon maybe this guy got the reading wrong, coz the revs didnt increase gradually, i remember punching it a little between 3500 and 4800, coz i was using my left foot, and was only half in the car :laugh:
although it would still be over legal limit, i have no doubt.
The hotdog and the box resonator only have about 3 inches of pipe between them and they fit between the CAT and the bend before the diff. The box is about 25cm x 20cm so is pretty small. All my pipes are mandrell bent and I had it made to sit as close to the body as possible so I have max ground clearance.
If your over 100dB you may need to look at a bigger rear muffler as well.
The Ruling is...
Passenger Vehicles Made:
Before March 1985 96 dB
After March 1985 90 dB
R33 GTST
Engine Test Speed 4800 Rpm
Microphone placement
45 Degrees angle +/- 10 degrees
same hieght as exhaust tip +/- 25mm
distance from outlet 525mm +/- 25mm
This info taken straight from EPA and Testing Procedure Manuals
can post em up if you want...
Cheers
RellikZephyr
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
