Have owned car for 4 years.
Completely stock with the exception of a rb20 wastegate actuator.
Few marks in the interior and could use a paint job, but other than that its a great reliable car.
Within the last 2 years its had a new water pump and timing belt fitted.
Only reason im selling this is because i also have a r32 and a 300zx, its just not getting driven enough and its a shame to see it sitting there.
The following pics are a few years old now, will get some current ones tomorrow. Same car, just has a bit of paint fade and stone chips at the front.
Looking for 6500. So low mainly due to the fact that it does need a paint job.
EDIT: Forgot to add, its got 140,000 k's on it
Edited by kjb_r33
https://www.sau.com.au/forums/topic/148451-sold/
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
  • 4 weeks later...
Sold to me,
Thanks Ken,
Going in for a minor Straight and Paint this week, i will send you photo's when it is done.
Drove it home well over 700KM's did not miss a single beat
P.S. the other item is in a post pack waiting for the post office to open tuesday.
Cheers
https://www.sau.com.au/forums/topic/148451-sold/#findComment-3170986
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
