I have spoken with my insurance company, and they have confirmed it is a repairable writeoff - meaning it can be registerred in the future...if that helps to all those who enquired
if people are interested in actually fixing it, the insurnce assessor reconed about 10k to fix...so i think someone that knows what they are doing, knows who to buy from and has the time one their hands, could probably get it done for $8000 - $8500 (if not less) at a rough guess...
https://www.sau.com.au/forums/topic/148690-sold/#findComment-2782161
i know its a long shot but im after the drivers side blinker, the little one that sits in the guard. need it urgently if your still wrecking + the passenger side vent
cheers
Edited by OnAhigh
https://www.sau.com.au/forums/topic/148690-sold/#findComment-2782478
some more pics...
am contemplating taking parts out to make it cheaper...as follows
- without the turbo $5500 ono
- without turbo and gearbox $4800 ono
-without turbo, gearbox, bov and rims $4300 ono
(if the rims arent sold with the car, then arrangements must be made by buyer to have a set of rims for the car for transporting)
https://www.sau.com.au/forums/topic/148690-sold/#findComment-2787746
i am fairly sure the motor is in working order, the radiator fan may need to be replaced by the look of it, but cant really tell until the front is pulled forward a bit
the radiator was busted in the accident thats why i havnt attempted to start it, for fear of over heating a ceasing...
https://www.sau.com.au/forums/topic/148690-sold/#findComment-2791549
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
