Originally bought the piping off Beer Baron here - http://www.skylinesaustralia.com/forums/in...c=143480&hl. Piping is exactly how beer baron describes it.
Looks much, much better than the stock stuff and apparently has some performance benefits as the pipes don't expand like the rubber ones under full boost. Plus the hoses are not as susceptible to blowing off as the stock ones are. The kit comes with the Greddy Alluminium hard pipes, silicone hoses and hose clamps. The hoses are ok, but have seen better days looks wise.
I'm asking 350 plus freight. Selling due to no longer owning an R33 GTR - ** NOTE: IT DOES NOT FIT R32 GTR **
I Also have a standard R33 GTR radiator fan in good condition - much better than R32 one, and will fit all RB water pumps.
Asking $50 pick up or $65 delivered Selling due to no longer owning R33.
Pair of Red Bride Brix seats with rails to suit R32/R33 etc, in perfect condition. Asking $1600 plus freight. Selling to update to a fixed back Bride and a Brix II.
New HKS SR20DET Inlet cam gear - SOLD.
S13 Cusco Adjustable Camber tops - SOLD.
**Please note Black Bride in Picture has already been sold.
S13 Hybrid Intercooler kit, with Turbosmart BOV - Asking $450.
Cheers
Edited by ookami
  • 4 weeks later...
would this fit r32 GTR or not??? cause the coolers are very similar!
let know via pm if you can mate, thanks!
STILL FOR SALE???
very interested...
I have Pm'd you,Consider sold if still up for sale!!!
  • 1 month later...
Pms replied too. sorry for the late reply I haven't been on here since i sold my R33, still for sale.
Edited by ookami
if these replaces the stock items on the r33 gtr then consider them sold
how much posted to nsw 2218...if you're close ill come and pick em up.
cheers
jeff
  • 1 month later...
cheers
jeff
Sorry for the late reply I haven;t been on here for quite some time, yes they do replace standard rubber R33 piping with alloy solid piping. Could do it for $365 delivered.
  • 1 month later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
