I have a S2 R33 and my side skirts have been cracked and look tacky for AGES, the glue came off the side and the screws were over tensioned and cracked them.
Last night I saw an R33 with what looked like NO skirts, just straight to the body of the car.
If i take mine off, what is underneath? would it look OK without the skirts on until I can afford new ones? (i.e. better than driving with cracked taped on ones).
https://www.sau.com.au/forums/topic/150077-no-skirts/
It will look fine...
My car had no skirts when I first bought it.
It will kust be dirty under where the skirts were.... :)
https://www.sau.com.au/forums/topic/150077-no-skirts/#findComment-2798681
It will kust be dirty under where the skirts were.... :(
:) sweet, I will do that when I get back home, give it a good polish where they were and hopefully it doesnt look too bad. :mad:
Thanks mate
https://www.sau.com.au/forums/topic/150077-no-skirts/#findComment-2798750
  • 3 weeks later...
if you have the type m skirts dont take them off as you will have about 4 holes on each of the body of your car where the skirts sit on the skirts skirts have plugs that go into the holes into the body so they can mount on
https://www.sau.com.au/forums/topic/150077-no-skirts/#findComment-2841903
Ahhh ok, thanks for that. I will just have to get the stock ones plastic welded, or buy some aftermarket ones. There is one big crack, almost full depth of the skirt and a few smaller cracks starting to form near high stress points like around the screw holes etc.
https://www.sau.com.au/forums/topic/150077-no-skirts/#findComment-2843275
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
