im in the stages of painting my rocker covers . and i was thinking of doing the cam cover , i wanted to know will the paint be able to hold on this?
also the black coil pack cover? could that be painted with the same stuff even though its plastic - or would it eventually just peal off cause its not metal?
cheers
https://www.sau.com.au/forums/topic/150105-cam-cover-paint-question/
you will want to work out if you want it smooth or not, currently they are not, if you want it smooth then a primer will be required to fill the gaps
sand that back and apply paint (using a primer/filler in a can wil ensure it is primed sufficiently)
cam gear cover is metal thats painted, 400 wet dry and paint straight over it
primer and paint stick to plastic without issue, may not be completely scratch resistant without a primer though
alright thanks for the help guys . i will use some primer on the plastic coil pack cover , and sand it to 800 gritt wet n dry which i did with the rocker covers .
also i wanted to ask is the cam cover hard to remove?
remove the crank angle sensor
then undo the 5 bolts holding the front panel of the cam gear cover. be sure to mark where the CAS is set at so you can put it back to the original settings
  • 3 months later...
isnt this pointless as you end up spraying over your marks anyway?
not really, as i would be taping up the rubber section so as not to paint over it, always looks tacky if people paint over this area - as its rubber and the paint peels off ..then you run the risk of if flaking off the main panel as well.
umm you should remove the rubber piece (it slips out). tape on out side to show the position, make the small mark on the inside, paint it. When dry put a piece of tape on the outside corresponding where the inside mark is. that way when you refit it all you have to do is remove the tape, if it is dry no probs :laugh:
i got high temp engine paint, as im doing cambelt cover, cam covers and plenum, should i still use primer and clear?
used 3 good coats of primer, about a 7-8 coats of colour and 2-3 of clear,
PREP WORK GUYS!
my finish is very let down by the preperation time, used a 200 grit to rough it up, a 320 to smooth it, a 800 to ready it for primer, a 2000 after primer before paint (wipe down thoughly every sand too!!) and long even strokes of paint finishing the spray OFF the item
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
