Hey all,
Im currently building a audio system ~1000WRMS. I was told its a good idea to upgrade your grounding points. Also heard that the Skylines have been known to have bad grounding points. Anyone had a problem with this? :)
As for upgrading the grounding points, is it just a matter of adding a few xtra 4Ga grounding cables to my -ve terminal: -ve to chassis, -ve to block? Any other points i should be focusing on?
Cheers.
https://www.sau.com.au/forums/topic/150824-xtra-grounding-points/
Hey all,
Cheers.
Yea that'll help ya a bit, probably need to add extra grounding points in the engine bay and to the battery (i think) cos i know my r33 for sure has an earth issue.
Best spot to ground your amp is to thick clean metal, using a big ass bolt, try and find some factory bolt and clean up the surface a bit aswell should be ok, you just don't want engine noise if your going big stereo n all.
the people who whinge about skyline grounding points are probably running bullshit power that the stock wiring system was never designed to cope with.
Which is why im asking if xtra grounding points will help. Btw person who told me he had problems with grounding wasn't running big @ss power hungry amps, stereo looked stock, car had 300rwkw not that this affects the current draw much.
Anyway which grounding areas should i be looking at upgrading besides -ve terminal to chassis & -ve to block? Someone mentioned to me that u can use a busbar like one below. Doesn't look to presentable tho.
If I were you, have a search for the Apexi grounding unit (or those other brands that come in a blue box), and see what the manual says. From memory, there was the block, the alternator housing, somewhere around the strut towers... and a few more.
Maybe even just look through apexi's manuals and see what their kits ground?
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
