Hi guys
I have decided to set my car up different now so i am selling my 2 defi guages with the link meter and all the sensors etc and also a Greddy water temp thingo.
the guages are boost and oil temp.
Looking for $400ish neg. for the lot
cheers
Edited by yoshiE
pretty sure they go to the stop when off, when you turn them on they move all the way to the top then back the 0 so i am to believe....
also they been in a box from when i got them, i just checked then and tapped it and its back down now... :wave:
guess it just got jolted in its travels
hey mate, not sure if you have the same gauges as me but if the are the link meter BF series they are supposed to be blacked out when off, also the controller looks alot different to mine! just wondering.
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
    • I've never understood why this bothers people. Surely you'd be looking at a T3 flanged Garrett style thing, rather than a TD? You're unlikely to push a +T hard enough to need that much fuel. If you're not starting with most of the things you need to do that (ie, the bloody ECU!), you're better off just going Haltech/Link. You wil hate life a lot less. No. Just no. Just turbo it as is.
    • Have you noticed if the squeak changes with temperature or after driving in the rain?
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
