Guest Des5001
Hey i have a r33 GTS-T series 2 1996 model and i smashed it, sucks bad. i had insurance thank god!
i live in orange so no one round here plays with skylines very often, but my smash repairs is havin troubles gettin parts so i was just wonderin does anyone no of places to try cause they cant start repairs till they have all the parts of something and im killin to get it back. thanks
https://www.sau.com.au/forums/topic/152167-spares/
Hey mate try post the parts you need in the wanted to buy section also the parts section skylinesaustralia is pretty huge try searching through there im not sure what state your in but mayber goto that section of this website and ask around there.
Good luck :D
https://www.sau.com.au/forums/topic/152167-spares/#findComment-2833459
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
