a set of rims I recently bought are now up for sale as I've found a set of 18's I want more
WORK 'ewing' 2 piece rims
black centre chrome lip.
17x8 fronts 17x9 rears, 114.3x5 stud pattern (nissan, toyota, most jap 5 studs....falcons)
unsure of offsets, stickers hard to read, but fit my R33 perfectly :P
they have 235/45/R17 Brigestone Potenza RE030 tyres front an rear with 80-90% tread left
SOLD
Cheers
Berin
[email protected]
https://www.sau.com.au/forums/topic/152455-sold/
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
    • Yeah so physically that port is consult not OBD2, but also be aware that "JODB" is not really a thing - it came in around 2000(ish) but is not a standard like ODB is, each manufacturer had differences. If you are looking at ECU only and have a standard ECU, go with Datascan as Turbo Tapin said. Per another recent discussion here thought that won't do other systems like in a modern car, for example bleeding ABS
