I have an avc-r installed and have made up a plate to go over the ash try hole but i wish to have someone fit it profionally into the hole so it sits flush with the rest of the dash.
Has anyone ever done this in an R32 in Adelaide? If so where.
Cheers Ryan
https://www.sau.com.au/forums/topic/152671-apevi-avc-r/
Cheers Ryan
http://www.skylinesaustralia.com/forums/in...st&id=67468
is that what you are thinking off?
https://www.sau.com.au/forums/topic/152671-apevi-avc-r/#findComment-2840778
ceedub.. thats the one bro. did youd do it yourself?
yep, just take the ashtray out and use a sharp knife to cut some material away so you can slip in the unit from behind the shroud (slip it in from the driverside. I superglued some metal brackets behind the shroud to support it so it doesn't fall.
I am sure there are better ways to do it.
In case I ever get rid of it I can always put the ashtray back in place
https://www.sau.com.au/forums/topic/152671-apevi-avc-r/#findComment-2843715
isnt the unit wider than the ash tray/ so there for if u put the tray back in it would look shiet
the unit goes in from behind so some of it is actually covered on the side.
Maybe I should check to see the ashtray actually fits normally - it was a while back since I did this.
I'll take some pic while I'm at it.
https://www.sau.com.au/forums/topic/152671-apevi-avc-r/#findComment-2846880
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
    • thanks, will conduct myself accordingly. i unfortunately put about 150 miles on the car before reading this thread again, however no PS issues, and definitely no turbo issues. it spools normally and still feels fast to me, probably because my previous car was an N/A auto sedan...gonna go fix the PS vacuum line though lol. safe to say, got what i came to this thread for. thanks
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
