  • Replies 117
Might be a good idea to tidy up the first post to clealy show what is sold and what is still available.
Hey mate, i'm after the bit that holds the battery in place. Tried calling, u must be busy.
best to buz me on saterdays around lunch time i should have it i only go into garage on weekends to busy cheers
hey mate,
how much u selling those rims?
I think u need a price on them as per the forum rules!
if u were a serious buyer and wernt tight u could have called me and asked $2200
you got the coil packs
HI CHAMP COIL PACKS ARE GONE WITHT HE COMPLETE ENGINE BEST GUY TO CONTACT FOR THIS WOULD BE
G-R CONSTANTINE JAPANESE USED SPARES IN WETHERILL PARK 9609-2566 OR
SYDNEY AUTO DISMANTLERS GREENACRE 9709-2800 CHEERS
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
