well since my bosch 040 died i pruchased another one.
ive recently installed it a few weeks ago and now its making this weird sound, not the hissing one which is normal.
its the same sound i had with the old pump, would it be a faulty pump or something else?
help would be apperciated.
https://www.sau.com.au/forums/topic/153572-fuel-pump/
generally fuel pumps (larger ones) will make a electronic type humming sound, apart from that sound which you said its making.......whats the wierd one? are you sure theres not a loose wiring connection, or perhaps fuel line problems somewhere inside?
https://www.sau.com.au/forums/topic/153572-fuel-pump/#findComment-2856941
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
