Nismo GT500 Urethane shift knob
10mm thread - (Please note - Fits all Nissan 5-speeds, but won't fit a 6-speed)
Same knob as in the Z-Tune GTR
Brand new condition - used for a week then went back to stock knob
Comes in box with Nismo 5-speed decal
$90
Apexi Power Intake pod filter kit
Excellent condition - was put on my car just before I bought it, I put the airbox back on straight away
Done less that 100kms
Comes with - filter, bolts, gasket, bracket, instructions
$90
Stock R32 Gts-t springs
Excellent condition, travelled around 80,000 kms
$50
JL Audio boxed 12" subwoofer
Very good condition
$50
All items in Melbourne, will post at buyers expense.
Edited by thumpr
Yes pod still avail - in melb cbd
jeff - the sub and box are pretty big and heavy, that's probably the one thing not worth posting
nismo knob is priced for a quick sale - it's elsewhere on this site for $140
Edited by thumpr
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
