Pics for Dale (didn't know where to post them!)
....and i'll show ya this one too....
There are more, but it was a dull and rainy day, so they aren't great pics.
Dale if you want any of the other pics I took, then I can email them to you, I didn't post them all up because a few have the numberplates in them and i cbf blurring the plates out. :)
Originally posted by Milk
the name of the exhaust
isnt it called:kimazaki or some thing
thats the kakimoto racing symbol... ive got a big one off a GT4 in my garage.
The symbol goes with the exhaust - ie its not just a badge :D
Its a Kakimoto cat-back exhaust.
Thanks K [r31sKylinechicK]! Yeah send em thru thanks: [email protected] :)
Daz: thanks mate, I bought if from a private importer under the old scheme late last year!
:) its only got a 2 1/2inch pipe tho... so i was going to cut it off and replace it with a 3" or 3 and a half :D
its got a 4 inch tip with a 5 inch silencer on it... and its all nice and shiney :D
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
