Would like some advice from anyone, regarding the best way to get some good results from my R33.
It currently is 228rwhp. The engine is pretty standard at the moment.
I have an Apex GT intercooler
Cold air intake
Pod air filter
3" exhaust with Dual dump pipe
I am considering getting a Apexi PFC with H/C, an HKS exhaust cam pulley and probably a Apexi boost controller. Got pretty reasonable prices so far roughly $2100 for the lot. But after speaking to few people not sure if the Apexi is worth it. Been told the Autronic SM2 is much better but its alot more expensive. Also been told to upgrade my turbo. This option seems like the expensive option but probably get best results.
Any advice would be greatly appreciated.
Thanks
https://www.sau.com.au/forums/topic/15405-more-kw-wanted-help/
Probably want to spend about $2500.
Haven't read that much about wolf. Thought Apexi was one of the better ones.
Got quote back today;
APEXi Power FC - 80,850
APEXi Power FC Hand controller - 28,875
APEXi Boost controller - 30,723
Exhaust cam pulley - 12,123
Shipping - 3,300
TOTAL 155,871 yen or
AUD$2059.76
Seems pretty good value but not sure if its gonna give me much more KW?
Thanks
Chris
GTS 33 - what power goals are you looking for?
If you looking for around 200rwkw then the stock turbo should be OK if tuned right.
But if your looking at 250rwkw, then go a different turbo. But if your stuck on spending $2500 then keep the stock turbo.
I think your on the right track. Spend the $2100 on the mods you've listed (remembering that you'll need to fork out more cash to get the PFC tuned), and always put a bit of money aside for the unexpected.
Have fun :)
J
Originally posted by GTS 33
Yeah thanks for the advice Jay.
If eventually I do fork out for a bigger turbo is the Apexi PFC gonna beable to manage it OK?
Thanks
Chris
The PFC won't have any problems at all.
There are 700hp+ skylines in Japan using the PFC :)
Like I said, just leave a bit of money aside, once tuned you may find that you need to replace your fuel pump or something.
BTW: where are you getting the parts from? Seem like pretty good prices.
J
If you do end up getting a fuel reg, the Malpassi brand is very commonly used and are around $300 new I think. A mate of mine picked one up 2nd hand for $150. If you are looking at plug and play ECUs, have a look at the Microtech model for R33s as well as these are $1300 new and do not require the Airlow meter. As usual, allow for tuning.
go off what boostd has done. he got 216rwkw out of the stock turbs, and as soon as he upgrades that or if he does, he is guarnatied to reap the rewards of smart modding.
he has a lot of good gear from what i read on his thread.
stock turbs he ran 12.9.
rev210 has another example too, if you read his posts.
dont go spend big on stuff if you are not going to complement that mod with another.
e.g, no good getting a massive set of injectors, if you still running the stock fuel pump. 1 mod is always linked to another in most case, which makes it hard money wise to sort and plan it out.
laters
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
