Hey,
I've had a problem I have been trying to sort out, that is the car popping/misfire on load at 4000RPM and above. I have cleaned the AFM and put in PFR5G spark plugs in.
I have fixed the problem from misfire from 4000RPM - 6000RPM from there it will pop and hesitate between 6000RPM - 7000RPM before changing gear (automatic)
Any ideas?
Edited by ThugishPimp
https://www.sau.com.au/forums/topic/155639-quick-question-please/
well 5 heat range is too hot, most use 6
checked your coils for cracks? boost below 12psi?
Thats what I thought. Stupid Autobarn.
Would having the heat range at 5 cause this to happen? I've been told by many to use the heat range 7.
I'm running stock boost, coil packs are fairly new spitfires.
Thanks for your help Craved!
I have tried BKR6E also and had the same problem. After I cleaned the AFM I only had the misfire from 6000-7000RPM and not 4000-7000RPM.
I have been told to try heat range 7. I got a set of BKR7E. Should I give it a go? Only mods are; Modifications:
- K & N Pod Filter
- Cold Air Intake
- Forged Pistons
- Strengthen Conrods
- Blueprinted
- Balanced
- Port Polished
- Metal Head gasket
- Spitfire Coils
- High Performance Timing Belt
- High Performance Spark Plugs
- Gready Turbo Timer
I've put in all new BKR7E spark plugs. Took it for a run it popped/misfired between 6000 and 6500RPM then changed gears, didn't seem as bad as it was when it was popping/misfiring between 6000 and 7000RPM.
Went to a friends after taking it out, on the way back I wanted to see if it would still do it, and I had no problems.
Now, here's the problem;
This has happened before, it will miss/pop then run fine for 1-2weeks then it'll pop/misfire again.
I can only hope the heat range 7 plugs doesn't cause it to pop or miss in a couple of weeks.
Any comments, suggestions?
what fuel are you using out of curiosity ?
V Power Racing (100% with 5% ethonal)
is it in tune? That could also be an issue, trial and error. Changed fuel filter? Any knock? Injectors? O2 Sensor? hmmm run out of others.
Not sure
Adam
I've had the fuel filter checked, no knocks, injectors have just been cleaned. Not 100% sure on he 02 sensor, but when it was in the performance shop they said they checked everything.
They said it was most likely my coil packs but since the rebuild had just been done then I couldn't get it on the dyno and rev it too high.
5 is the standard heat range. if you're running close to standard power then colder plugs shouldn't be necessary.
Edit - popping and misfiring is very likely to be tired coil packs. Gap your plugs down to 0.8mm and give it another shot :huh:
Edited by Kinks
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
