Up for sale is our R32 GTS-t, built by TRIAL tuning house in Japan, there isnt much this car does not have!
-RB25DET, the motor has been built, not sure on exact specs, I know it has metal head gasket, after market camshafts, forged pistons, ported head ect.
-RB25 Gearbox with OS Giken crossmission gearset
-OS Giken twin plate clutch
-KAAZ 2 way mechanical diff
-TEIN RA coil overs
-Adjustable castor rods
-TRUST TD06-20g turbocharger kit
-TRUST intercooler kit
-NISMO 555cc injectors
-NISMO fuel pressure reg
-SPLITFIRE coils
-BILLION aluminium radiator
-R33 GTR BREMBO front brakes
-R32 GTR front guards, bonnet and bumper bar
-WORK Meister S1 wheels
-TRUST 80mm exhaust system
-BRIDE drivers seat with Willans harness
-GTR passanger seat
-CUSCO roll cage
-GREDDY guages x 6
-Autometer RPM guage
-AP Engineering APEXI power FC
-HKS boost controller
-APEXI RSM
-VEILSIDE cluster
The car makes 280rwkw on a lowish 1.2bar, it has been very reliable and does not miss a beat, the car has current Victorian registration untill March 2007, it will be sold as is with no RWC if sold in Victoria for obvious reasons.
The car is now plain black and has no stickers on it.
Asking price for the car is $19000.
PMs will be replied to or you can E-Mail direct at [email protected]
Edited by Creatd Motorsports
https://www.sau.com.au/forums/topic/156108-sold/
rb25 engine but rb20 gbox? i can understand if it has an rb20 gbox behind it if its got an os set in it... however since when is an rb25 pfc produced by AP?
do you maybe have it around the wrong way? rb20 engine and rb25 gbox with os set?
https://www.sau.com.au/forums/topic/156108-sold/#findComment-2906408
no, trial built RB25, RB25 box with os giken internals. PFC is AP engineering and runs "psuedo" d-jetro. i think typo on box.
Edited by URAS
https://www.sau.com.au/forums/topic/156108-sold/#findComment-2906738
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
