Selling the following:
KCA331 Caster Kit
https://www.whiteline.com.au/store/default.asp?part=KCA331
RRP: $129.00
Group Buy Price: $110
My Price: $90
KCA347 Rear Camber Kit
https://www.whiteline.com.au/store/default.asp?part=KCA347
RRP: $146.70
Group Buy Price: $123
My Price: $100
I bought these from the Sydneykid bilstein/whiteline group buy, however I was convinced to use the cusco camber arms and castor rods that I already had, so didnt get the above parts installed.
I will post, or pickup is available from Clayton, Melbourne.
Edited by wixy
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
