PRICE DROP!!! Can go a little lower in price if buyer picks up and pays cash :D
Emotion Work CR KAI rims - Asking for $1500 with Federal 595 SS 85%+ tread on all 4
No gutter rash or damage to rims!! Awesome condition and price - Almost $2800 worth of rims & tyres!
They would of barely travelled 1000kms!!
4 x 114.3 17" x 8.0 +32 Offset - Suits S13, 180, non turbo skyline, and of course Cefiro / Laurel
This is how they look on a car
PM me if interested or post here!!
Hey mate i would love a few pics on the wheel and the guages if ya dont mind can get my sis to pick them up if i buy them
Hey what stud pattern is the wheel, I mean is it a uni fit one? PM me please thanks
Hey where ya located. interested in the BeeR pinapples.
I am in sydney
adam
Am located in Pennant Hills and Artarmon.... so either or if interested for pickup
Do the gauges come with senders?
I can organise for them to, just got to remember where i put them :sick: Will update this weekend when i am back at the car/garage
PS Price drop on rims... $1800!!!!!
Bumpety
Ok all have replied to PM's and updated prices on original post :domokun:
The rims can be posted, BUT at buyers expense and they have to organise it!! Just get a quote for pickup from Mascot NSW as i can take them to work for ease of pickup!!
PS... why noone snapping up the Bosch 044... $225 is the cheapest around!!!
Catch yas
Ando
PMS REPLIED TO
PRICE DROP ON
RIMS - $1650 - Now thats a bargain :wub:
BOSCH 044 - $220... Pretty much the cost of a 040!! WOW :woot:
Gauges - Check for senders but can't find em :P So $80 now, comes with all required wiring!
What size are the tyres? Very interested - just trying to organise shipping.
I need to know the weight of each wheel also please
Tyres are 235/40 x 17"
Weight... not sure can weigh one this weekend for you! :happy:
ALL PMS REPLIED TO :kiss:
Update - Weight of an individual rims is exactly 20.8kg. Thus total weight for shipping purposes for all 4 rims is 83.2kg's
Cheers,
If people are interested in items to be posted, it is at buyers expense and buyer to organise.
Rims still going cheap! Bosch 044 still going very cheap!
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
