Hi, I have a brand new Garrett GT42 for sale. i'm asking 2500OBO. Reason for sale is i'm going with a different setup. I paid over 3000 USD for this turbo and i'm letting it go for 2500 AUS. If your a serious buyer i'll pay for half the shipping cost.
please pm me if your interested or post up
$1500 AUS plus free shipping
Specs
Compressor specs
wheel dia 76 mm
wheel trim 52
A/R ratio .60
Turbine specs Wheel dia 72.5 mm
wheel trim 84
A/R ratio 1.15.
Pics
http://i26.photobucket.com/albums/c105/FOO...cture064zx7.jpg
http://i26.photobucket.com/albums/c105/FOO...01/DSC00364.jpg
http://i26.photobucket.com/albums/c105/FOO...01/DSC00363.jpg
http://i26.photobucket.com/albums/c105/FOO...01/DSC00361.jpg
http://i26.photobucket.com/albums/c105/FOO...01/DSC00359.jpg
Edited by FOOT
https://www.sau.com.au/forums/topic/157533-brand-new-gt42/
  • 4 weeks later...
have you tried the supra forum or calaisturbo,not sure this size journal bearing turbo would spool up too well on the smaller RB's,most would go GT35R or TO4Z for big power i would imagine,one of the calais boys might want it for drag purposes?
good luck with it
https://www.sau.com.au/forums/topic/157533-brand-new-gt42/#findComment-3022831
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
