the ad says that they're aero fenders,and they don't know if they're normal size of flared. - "normal size?"
they're most likely no bigger than your std guards,they just have some vents in them.
they'll look pretty anyhow,so it's no loss.
Justin...
https://www.sau.com.au/forums/topic/157624-score/#findComment-2927716
i hvae 4 grand to dump. might as well make it well rounded right?
only thing i haev to do to my motor anyways is a GT25 and injectors. i have the rest laying here, z32 mafs, gtr fuel pump, safc2, gtr fmic....
https://www.sau.com.au/forums/topic/157624-score/#findComment-2929996
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
