Hi all.
Well it apears i have a leak in my gasket between the maifold, and i am going to replase it, just cos i'm a pedantic anal little so and so. My manifold is great nick, BUT i can't have the car of the road for more then a day.
SO what i need is to borrow a stock manifold, that i can machine up to ensure it is flat, sandbalst and paint up and then install on the car. I want to do all the painting and so forth, before i pull the other one off, to minimise any supprises.
SO i need to borrow a manifold, and once i have mine off, i will blast and prep that one the same way as the one i installed and give it back to the owner as exchaneg.
KAPISH?
ok so who has one?
THANKS
https://www.sau.com.au/forums/topic/157661-wanted-to-borrow-and-then-give-back/
