post-28634-1172657408.jpgMitsubishi 6A12G MIVEC V6
RPW carbongraphite decompression head gasket (approx 9.0:1)
Custom Garrett 450hp hybrid ballbearing turbocharger (T28/T04 hybrid)
Custom 2.5' mandrel-bent dump pipe
Custom stainless exhaust manifold
Custom turbo intake feed pipe
Custom stainless intercooler piping
Custom 2.5' mandrel-bent mild steel exhaust (cat-back)
Custom Genesis-tuned Microtech LTX-8S ECU
6x Bosch 480cc injectors
Walbro 500hp in-tank fuel pump
Apex'i air-pod filter
Apex'i AVCR Boost Controller
Custom front mounted air-to-air tube & fin intercooler
HKS Super Sequential Blow-off Valve
Samco silicon hoses
Braided oil lines
Modified inlet manifold
Custom oil breather tank
NGK Iridium spark plugs
Speedflow anodised hose fittings
Custom radiator and air filter heatshield (in carbonfibre)
Engine modifications worth all ($9,000)
DRIVELINE:
Factory 5-speed manual (modified with stronger internals)
Exedy Hyper single plate heavy duty clutch with lightened & balanced flywheel
Rare factory LSD
WHEELS / BRAKES / SUSPENSION:
17' BuddyClub P1 Racing lightweight Japanese alloy wheels with Bridgestone Potenza G3 tyres ($2,000)
Sheepdog Prof-Sport springs ($350)
Cusco upper strut tower brace front & rear ($500)
BODYSTYLING:
Custom aero front bumper (GPvR/DCuatro hybrid)
Genuine C-West carbonfibre front canards
Custom modified Kansai wing (ala Porsche GT2-style) ($2,000)
High-Intensity Discharge 7500K headlight conversion **SOLD**
I.C.E:
Panasonic MP3 head deck
1x Cadence Q4000 4ch amplifier
1x 12' Phoenix Gold Tantrum 12D subwoofer in sealed enclosure
Kenwood front coaxial speakers
System worth ($1,000)
INTERIOR:
EL gauges ($200)
Defi Heads Up Display ($350)
Pivot turbo timer
Razo gearknob & pedals
Sabelt harness pads
AVCR boost controller ($400)
Factory genuine Momo airbag wheel
For that enthusiust who want to be different,
Stiil has more power left in the turbo roughly another 150KW, needs internals done.
Price: $17,500
Alot of $$$ spent, true sleeper!
RWC & 12MONTHS REG.
post-28634-1172657408.jpg post-28634-1172657580.jpg post-28634-1172657687.jpg post-28634-1172657812.jpg post-28634-1172660889.jpg post-28634-1172660985.jpg post-28634-1172661119.jpg
  • 1 month later...
  • 1 month later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
