hey all, ive just invested in a 1993 32 4door,after bein told by a local shop that they can comply it, now that i have payed for it, i went back to the shop to get my import approvel only to find out that they only do 2 doors... i now have it sitting in a mates yard in japan waitin for me to get import approvel.. does any one know of any one in SA who does r32 4 doors?? if not in this state a cheap one in victoria or some where close... thanx heaps guys and girls
https://www.sau.com.au/forums/topic/158674-sevs-for-32-4door-in-sa/
I'm suprised the no. doors matters, I'd be making a phone call to check up on that, but according to DOTARS Website these are the SA workshops with RAWS for R32s.
Company Name CLIFFDALE PTY LTD
ABN 87 008 203 361
Trading Name CLIFFDALE PTY LTD
Address 97 MULLERS ROAD
HAMPSTEAD GARDENS SA 5086
AUSTRALIA
Company Representative Details:
Contact Name Mr IAN SMALL
Phone 08 82665777
Company Name REDICORP PTY LTD
ABN 20 090 546 526
Trading Name PVP IMPORTS AUSTRALIA
Address 51 MAIN NORTH ROAD
MEDINDIE GARDENS SA 5081
AUSTRALIA
Contact Name Mr Robert Redic
Phone 08 8367 5261
Company Name EMPIRE NOMINEES PTY LTD
ABN 90 089 273 521
Trading Name IMPORT COMPLIANCE SYSTEMS
Address UNIT2 / 1 SLEAFORD RD
WINDSOR GARDENS SA 5086
AUSTRALIA
Contact Name Mr Simon Firth
Phone +61 08 82610006
All eligible R32's (incl GTRs) are under the same SEVS Entry No.
http://rvcs-prodweb.dot.gov.au/sevs/009-01.htm
thanx for ya help, i found all them the other day and spoke to them all, the have all told me they cant do it, i rang every one in the victorain list as well, they all tell me the same, i even have one dude tell me that know one in australia does them... i dont knoe what to do now, i have a car that i payed for just sittin there...need more help :O
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
