Hi, For sale is a full rear adjustable camber kit (only half a kit is shown in photo, U will get ALL 8 bushes.) and 4 pineapples (2 large and 2 small).
I bought them in bulk and I have 2 complete kits left..
The camber kit is designed to give a range of 1.5 degrees of camber adjustment, because it is adjustable, it is possable to dial in whatever is required! This will help solve the 'scrubbing' of the inside of the back tyres.
The whole kit is made by super-pro, which means they ae Australian made!
This whole kit includes pineapples and full camber kit (8 bushes) for $280. $10 freight Australia wide.
You can PM me..or
You can email me on [email protected]
Edited by psi
https://www.sau.com.au/forums/topic/158967-full-rear-adjustable-camber-kit/
A FULL Rear camber bush kit retails for more than $270, the full pineapple kit is about $100
I don't really want to go any lower.
I'll do them for $285 delivered.
Edited by psi
I sold 1 kit, so I only have 1 complete kit left..
Ask your local parts shop, this is a very good deal!
I'm eager to sell the last kit so I can buy some more parts...
The whole kit for $280 delivered.
:D:D:(:)
well, all i have left is a set of 4 pineapples. as per foto!
these are very good for helping to get MORE grip!
They are easy to install (about 3/4 hour) u can do it urself with just a few tools..
and you don't need another wheel alignment!
$65! plus post.. $5
any takers..?
The pineapples are a bush that pre-loads the cradel bush that supports the diff sub frame.
By preloading the subframe in different ways,
it is possable to change the characteristics of how the bush reacts to the torque that is applied to it by the diff.
so, it is possable to preload the sub-frame 3 different ways.
1. maximium grip (which is what i use)
2. minimum grip (for drifting)
3. all round performance.
best of all, if you wish, u can remove the bushes and leave the car standard!
They don't take long to fit and you do not alter/change anything else.
just put them in, and away u go.
You can swap them around to 'tune' the rear end for track or drift days!
They do make a difference..
they do not have a profound effect like going from a street tyre to a slick,
but it is a noticable difference.
cheers
So I've ended up one the rear camber bushes coming back!
I still have the pinapples as well!
$280 delivered! for the whole kit.. FULL rear adjustable camber kit, and 4 pineapples!
Got pm.
Pineapples sent today!
I still have a set of rear adjustable camber bushes left. They will give you 1.5 degrees of camber adjustment!
Anybody interested?
$230 plus $6 Australia wide freight
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
